summerhouse build and walls stressing me out
14 Feb 2012
Nottinghamshire
Hi, i am new here, but have read hundreds of posts, i have started building a summerhouse/ garden room/shed, its 17 ft by 10ft, all the base is done and OSB boards down on the base, the frame work is up, now this is where i get stuck, i was going to put osb boards around the framework and then shiplap on top, then i changed my mind and decided not to put the osb boards on and just shiplap onto the frame work, i am now reading some more and i think i need to put a breathable membrane on it, now for my questions
1/ do i use a ply/osb board first is it necesary or can i go without
2/ if i don't use it how do i attach the breathable membrane to the framework
3/ then once the breathable membrane is in place do i attach batons??
im sorry for sounding thick this is the first build i have done and i would have got this far without this site, only i want it to be watertight, i have got some sliding double glazed patio doors to go in and i want the walls to be watertight, i would rather get it right first time thank you in advance
i was thinking, frame, 11mm osb board, or do you think i could get away with 5.5mm ply, then membrane, batons, cladding, and then on inside i was going to use rockwool between fram and then plasterboard could this work cheers
i know it costs more but please use 12mm exteriour ply from a wood yard you will get a strong long lasting structure where you can hang what you like from the walls with only the heaviest items needing extra support
a swivel chair or a heavy "thump" can damage 6mmply[5.5]
and you often get a beuitifull hardwood finnish
would also go for ply on the floor what centres are your floor timbers and what thickness is your flooring??
hi, i used 6x2 joists and i spaced then at 16" on centre then put noggins in everwhere then 11mm osb boarding on top, it really is solid, i will go with the stronger walls that you suggest, i hadnt eve though about hanging anything on the walls, i can get 11mm OSB quite cheap is this pretty strong? cheers
I would not use plasterboard in a timber out-building [likely to suffer from cold damp conditions], better to use ply internally.
I used 12mm ply to line my garage walls, allows fixing of shelving etc without problem.
as i say ply can give you a nice decorative hardwood colour and a relatively flat finish where as osb is rather uneven also tends to have a waxy finish
you should be ok at 16 centers but ply would be better for point loading like workbenches and chair legs
Big A ----I think the osb is for external only.
could be lol :D :D
hope its not on the floor as i suspect it may fail indeed my next suggestion was to knock some big nails into big timbers on a workmate or chisel a hole in timber to check the bounce and possible dammage
i have put it on the floor, but the timber place did advise that it would be fine, there is no movement, or no bounce anywhere and i made sure the joists were all solid and it has so many noggins in it is well supported, i have been and brought the rest of the wood today, so let the build commence, its looking good just hope it continues to
