Hi there.
Firstly i'm assuming that this is a receiver problem!
We've been running a sunvic rf tlx 1206/tlx 7506 thermostat with our Worcester 30 cdi combi boiler without a problem for last 12 months.
Yesterday i tried to call for the CH after a 2-3 month period of not activating CH and nothing...hmm
HW/thermo/boiler are all fine.
I've changed the batteries in the thermo / checked the wiring in the receiver /checked wiring/fuse in power switch / checked wiring from receiver to boiler/ checked mains fuses and wiring/reset boiler/ and all are fine and tight.
After changing batteries in the thermo, i thought i might need to re-commission the thermo to the receiver again [as stated in the sunvic instructions] but noticed the no green or red lights on the receiver.
The receiver is supposed to flash green when you request CH and flash red when it switches off CH. When you press the TEST button on the receiver its supposed to activate itself but NOTHING! Its as if there's no power to the receiver.
Is there anything else i could check or can you advise what the problem could be??????
thanks simpson
thanks simpson
