Superglue and an Acrylic Bathtub
7 Aug 2008
Yorkshire
Hi Folks
Thanks for all the advice that everyone has given over the past 6mths. The bathroom looks like a million dollars, and we were spoilt within 3days of putting in the CH!! :D
K, now for my Q.
We put up a shower shelf on the tiled walls to put our shampoos etc, using superglue. Except some of it spilt on fell onto the bathtub itself. Does anyone have any suggestions on how to remove it, pick away at it, or should i just let it be as might cause damage to the bath lining?
Thanks for any advice :)
Marie
PS I am not certain where to post this, so move it if necessary.
Hi, usually an acetone based cleaner will remove dried superglue, alot of nail polish removers are based around this.
It will not simply wipe off but with a bit of persistence it will start to remove it without any adverse effects on the bath itself.
Next time you want to stick anything, try & use silicone.
Its brilliant, the only issue is holding it in place while it cures.
word of warning if the supeglue gets constantly wet it can fail :cry:
try cyano debonder, thats what its made for :D
Hi everyone
Thanks for the replies. I will try and find some acetone based cleaner - any brand suggestions?
Murphy was hanging around, as the shelf fell down last night :!:
So would you suggest I use silicone on the suckers, or should I try with something else?
Marie :D
PS Bigall - the shelf is at the opposite end of the bathtub (1800) to the shower, so it should only be getting splashed occasionally.
:D should be ok as long as you dont have continuouse condensation running down the walls
Silicone, it holds my shampoo, soap dispenser, corner unit & they all take a daily battering, been up for 3yrs.
Its about holding it in place whilst it cures. I used masking tape lots of it
