Supplier of 1" float valve washers.
12 Dec 2004
Hi!
I'm after a 25mm Dia x 3mm[approx] thick rubber disk.
The closest think I can find is a 1" float valve washer. However these seem to be sold in packs with all sorts of other washers & not on their own. I've seen 3/4" in packs of 6 I think, but no plumbing supplier around me seems to have 1"...
I've also seen these in 3/4" brass end caps..... but it seems a waste to throw away a load of brass!
Any thoughts? I'm after 20 at least.
Ta!
Red, Blue, Green with yellow spots..... just need to know where from.
I tried eBay already - no go. Tries BSS as I needed to get a big float valve there once before as the PTS's, Plumbcenter's, etc of the world didn't have - but BSS don't do spares! D'oh!
I'm rapidly coming to the shamefull conclusion that when stuff just needs a spare, if it's not run-of-the-mill, it's far cheaper on time/transport to replace with new! D'oh! [again]
If you can let me have your e-mail adress I can arrange to send some
Thank you for another suggestion - Phil11 has kindly let me have a few! Sorted!
