supply for jacuzzi bath
19 Feb 2009
Glasgow
hi guys ..putting in a jacuzzi bath and going to supply it from an rcd socket....just wondering if it would be ok to supply the socket from the load side of shower switch .......obviously only the shower or the jacuzzi would be used at the one time
Err NO not from the shower circuit!!!
You could provide a fused spur from a nearby socket for the pump.
Are you really sure you know what you are doing?
the pump will need to be accessable, have you read the regs. BS7671:2008 on special locations?
the guy does not know what he is doing that is why
he came to the forum to ask advise
do you think someone who wants to do a one off job
reads bs 7671
the pump needs to be accessible i think he may have
thought of that
you came on here not so long ago and said the instructions for a stat were confusing
4 connections for christ sake every time you answer
a post with your high handed manner read back through your own questions ( i have)
now back to the op if you could give us a bit more info
we will try and help this work is notifiable but will explain
more about that later how far from the bathroom is your consumer unit ? whats the access like ie loft space
can you come under the floor
just looked you are in glasgow part p wont apply
is it select you have to conform with
