Anyone know what a typical OP device rating is (appreciate there may not be one)..
I also like to know what people consider best practice is for the following
Context is a re-wire where it would be better to service the property using 2 CUs.
Notionally 35MM SWA has been selected for feed between CUs (internal), which at 154A (clipped direct, 3 core) is obviously more than ample. Run is around 25M by the way.
Question is then what to run between the Isolation switch and Service Blocks (which will be 200A).
Allowing for known/ likely load diversity, 35MM cable should also be OK in practice, but obviously if the upstream OP is left at 100A (default supply breakers in the CUs), then the principle that the cable rating should exceed the upstream OP rating is not met.
Ging to 50MM cable would be one option.. but given that it twice typical tails size, it does seem excessive..
One possibility I suppose is to fit an inline breaker before each CU - 63A perhaps would be sensible.
Not having come across this before, I wondered what others might do.
