D
Deleted member 174758
Yes. It doesn't matter if the brackets are a tad too big, only that they don't touch the sub floor and have some clearance (to avoid creaking)
You cannot just support the frame on angle brackets - you level it onto packers (home-made plywood packers, plastic spacer shims, etc) then bracket it to the floor. I thought you were using some kind of rubber pad, though. One tip - if using crowned timber (i.e. timber with a few millimetres of belly on them), always place the crown uppermos as it will tend to flatten in service whereas a hollow is always a hollow.Will 100x100 corner brackets from Screwfix be up to the job of supporting the frames off the the conc. base? Or would something a bit more sturdy be needed?
You don't add a filler - I believe quite a lot of the D4 glues sold as flooring glues such as this Egger D4 glue already contain a filler. The last stuff we got from a trade outlet was opaque and definitely had filler in it. The filler is used to change the viscosity and helps if you are laying onto slightly unlevel surfaces (stops runniness).What's the glue filler for? Is there a PU/filler glue available off the shelf that's ready to go or do I need to mix in a filler myself?
0.5mm or so? The glue gets flattened down and squeezed out but is also partially absorbed into the tops of the joists and the sub-flooringWhat sort of glue thickness under the ply should I allow for? A couple of mil?
Standard approach. You can't always guarantee that all the timber you are working with are perfect so you need some way to work with slightly imperfect stock. But obviously you do want to start with the straightest stuff you can to start withI go thru the CLS in sheds and pick out the straight ones, but I'll put the rings to curve over. NEVER would have thought of it.
100 x 100mm? There isn't really a standard sizeI have various thickness ply kicking about for packs, what LxW do you use?
TBH I'd be fixing my timber packers down to the concrete sub-floor, then foir fine adjustment I'd use plastic packing shims - the sort used for door and window insallation, like horseshoe packers:Will 100x100 angle brackets be enough to hold the frames down once level on packs?
Yes2 screws holding each ply pack down to conc. base?
For 5.0mm screws I'd normally use brown plugs (7mm hole). Personal preference6x40mm rawl plugs?
Sorry, but 9.5 ot 12.7 to dust?The conc. isn't great, 9.5 or 12.7 to dust.
Yes. It's more to stop a pack if packers shedding bits as you work around the floor.A splash of glue between ply packs might not hurt, once levels are ok.
Why haven't you just screeded that floor, or am I completely missing the point?
threshold strip would give plenty for 6mm click vinyl/edge strip.If you need to find a tradesperson to get your job done, please try our local search below, or if you are doing it yourself you can find suppliers local to you.
