Supporting posts for a raised deck
8 Jul 2011
West Lothian
I'm building a raised decking area about 2m off the ground to support a playhouse for my kids. The area of the decking is about 5sqm, supported by 8 posts.
I'd like some advice on the footings for the posts as I can't decide whether it's best to sink the posts directly onto a base of gravel/stone at the bottom of a posthole and fill around with concrete, or otherwise just use a concrete in post support to keep the actual post above ground. The first option seems more stable though perhaps the post would last longer in a post support and kept above ground.
Both of your conclusions are true, so take your pick. You'll need some lateral movement prevention (as provided by posts down into concrete).
Don't forget to checkout the planning permission.
In this local authority, decking over 300mm above ground requires planning permission. I would think that this applies to all areas.
Frank
