OK so...
I've been planning a wraparound extension to my semi-detached house.
I'll be removing the rear wall of the house to open up the extension which will require steel. My problem lies with how to support this steel. The proposed solution is when knocking down the rear wall, to turn them into columns (which may need padstones/reinforcing) and to place the steel on these. The engineer employed has looked into the foundations that these columns will sit on and advised they aren't adequate and need strengthening. His remedy is to arco prop the rear wall, remove the existing foundation and install a reinforced concrete beam. However all builders (7 to date) I’ve asked to quote have either; not been interested as the job isn’t worth their time or said it’s over engineered and unnecessary (again not interested). I’ve gone back to my engineer and asked about another solution and he’s been inflexible and querying who these builder are, whether they’re any good. Building control advised me that they will only follow what the engineers have instructed and I need their plans to change before I start work.
So I’m currently stuck in limbo with where I stand. Is the engineer entitled to offer another solution? What other reasonable solutions are there (mass poor underpinning, steel goal posts?) Is the RC beam sound/Shall I keep ringing builders? Should I get another engineer?
It’s been over 2 year since I started planning this extension and I’m starting to reach boiling point and about to jack it in
The beam will be roughly 5.5 meters in length. I'm trying to upload the plans.
Thanks,
Neil
Thanks,
Neil
