Hi all
I could used little help with a problem I'm having with a Suprima 80
We have a Suprima 80 and a Gledhill hot water storage unit.
We have had countless problems with the Suprima 80 and earlier this year had the new replacement PCB fitted by BGS. In November the boiler failed again and BGS changed the
Fan Models 70 and 80
Pressure Switch
Temp Thermistor
Overheat Sensor
Spark Electrode
and another PCB assy (again the new style one)
We are now having problems again !!
The boiler is sitting on flashing green but the rads and water are not hot. Sometimes the boiler will fire run for a few seconds (usually about 10) and then switch back to flashing green. The water in the gledhill is about 54 so well below what it needs to be.
BGS have been out again today but no joy, so I'm (luckily) using the geldhill SWITCH to provide hot water and some heating. They are coming out again tomorrow with a the tech manager, but I would appreciate any advice in the meantime.
Does it sound like I have the new PCB with the new fault ?? and am I unlucky enough to have had 2 of the new control PCB both with the same fault
Thanks in advance
Cheers
Pressure Switch
Temp Thermistor
Overheat Sensor
Spark Electrode
Thanks in advance
Cheers
