I am planning to temporarily surface mount an oven socket and connection unit. The existing oven is already on its own circuit (32A MCB), although it is not RCD protected.
I am therefore planning to surface mount for now, until I can get an electrician in to add a new circuit under RCD, and then get them to chase everything in.
An electrician has told me that the existing oven cable is fine, but I will need to move it to a new location.
The oven is rated at 20A.
I plan to use the items in the screenshot below, and
- Run the existing cable to the new socket (all surface mounted)
- Run the new 6mm cable to the connection unit (all surface mounted)
I wonder if you guys could please advise on the following:
- Is it as simple as correctly wiring into the socket and unit, or is there something vital that I have not taken into account?
- Should I use heat resistant 2.5mm 3-Core from the oven to the connection unit?
- Do the rest of the materials look right? (I think 20A, surface mounted for 2m, requires 2.5mm, but 4mm if the electrician keeps it and chases it, so 6mm is just a bit of over-engineering)
