Surges or "High" voltage possibly killing stuff?
28 Jul 2012
Surrey
So i've been living in my new house full time for about 6 months now with all my stuff moved in, after previously spending around 10 months renovating my house.
Earthing system is split concentric TN-S according to DNO when I had them out last December to check the rating of my incoming fuse and also look at a old disused supply around the side of my house.
I come to notice recently a number of electrical items have failed in recent times, including:
1) A 110V tape cassette deck from Japan that runs on a small step down transformer that I have had for a number of years. Fixed by replacing a failed 1A glass fuse on the secondary side of the transformer inside the tape deck it's self.
2) A fancy colourful Glass LED mood bulb from B&Q, that has failed after 10 months from new when I bought it in Jan 2026.
3) A Philips Hue GU10 colour spot. I have a bunch of these, but now one won't turn on or reset.
Also I don't think so, but have my Hager SPD's in my consumer unit failed after only a year of use? I understand the window on them says "Defect" when failed, so I think they are ok, but not 100% sure. (I took them out to just to film the video and get a better look, since reinstalled them.)
My measured line voltage also often is pretty high-ish on the nominal 230v +10%/-6% range, with it peaking at 252 volts a few days ago according to my APC UPS data log. Right now and according to a separate plug in power meter, my voltage is 247V.
So my questions are:
1) Have my SPD's failed and need replacing? I don't think so, as I think the windows says "Defect" on them when failed afaik.
2) Is my high-ish line voltage causing things to fail and die, or is it just a coincidence?
3) If my line voltage is responsible for causing stuff to die, what can I do about it? I'm not that far away from a major large sub station, so I suspect that's why my line voltage is on the higher end.
Regards: Elliott.
