SWA current capacity
  • Thread starter Thread starter wiseingup
  • Start date Start date
I guess the intention is that a qualified person needs to select the correct mcb to match the cable size. ... Therefore parts can be replaced by diyers but not new circuits designed/created
Are you saying that you believe that changing an MCB (to one of different rating), alone, constitutes creation of a 'new circuit', and hence notifiable?
Kind Regards, John
I didn't say that. Nor is it a new circuit.
I know you didn't - that's why I asked :) I'm really just exploring the totality of the situation. IF you don't believe that changing an MCB to one of different rating creates a 'new circuit', then one could do that without notification (certainly in England). If subsequently (days, weeks, months or whatever later) one replaced the cable, that wouldn't be creating a 'new circuit' either - so, again, not notifiable. So, if it's not a 'new circuit' when the two parts of the job are done days/weeks/months apart, logically nor would it be a 'new circuit' if the two jobs were done on the same day(s), would it?
Kind Regards, John
New circuit or not, the fact is that it won't be notified in 99% of cases.
I don't know about the percentage but, in concept, you're probably right about DIY work.
But what about a self-certifying electrician? Do you think that (s)he would feel that replacing a circuit's cable and changing it's MCB to one of different rating did, or did not, require notification to his/her scheme (in England)?
Kind Regards, John
I would say that replacing a faulty MCB with the same would definitely NOT constitute a new circuit merely a replacement.
Fitting a different MCB - rating or type - would, by definition, make a different circuit and therefore, new.
