SWA set in concrete? w/pic
4 Jun 2004
I've got an SWA cable being put down under my patio, which happens to be quite low and needs to be built up on a bed of concrete, with a sand/cement mix going on top.
I've already found a previous post that mentioned concrete has corrosive type effects on SWA cable, so I'm just wondering how to do this? If it's not okay to lay SWA in a concrete mix, is it okay to lay SWA within a sand/cement mix instead?
The picture shows the SWA coming out in a mix of stones. This is where the concrete bed was going to be poured over.
Thanks,
Simon.
Why not run the swa in a length of pvc conduit? then if needs be you can remove/replace the cable.
:wink:
Because the cable comes up vertically and PVC conduit cannot bend very easily.
I need a proper reply please regarding concrete and SWA.
Simon.
yes it does
Simon.
i thought it was a reasonable reply.
as i said plastic conduit bends very easily, only thing is, dont think yor cable will fit easily down a20mm conduit
try push fit waste pipe instead
Any exposed sections you might worry about could just be tape wrapped. (gaffer tape or similar) Mind you, I'm not aware of SWA and cement, even with strong lime mortars, having any deleterious effect.
Simon.
Sorry if my answer did not live up to your expectations Simon :cry:
Maybe some planning "before the job" and you might not have to resort to getting "proper" replies!!!! :)
Found some flexible 20mm conduit. Here's the finished job, before the concrete goes down:
Simon.
He'll see the box on the wall, and lift that slab first. Not really a problem as the cable route is visible.
I don't see why you couldn't have just kept it buried until it needs to rise to the wall.
And I can't see any warning tape near the top of the cable, unless you've been neat with it's burial.
