Drilling into Patio Stone
4 Jun 2004
How do I drill a hole in patio stone?! Do I need a special drill bit as I don't seem to be getting anywhere!!
One other questions...
Is it okay to base up a patio with a concrete mix and then use a combination of sand and cement to lay on top for the patio to sit on?
Thanks,
Simon.
to add to that you are using a sharp masonary bit arent you?
It's a good bit, but I've only got two 10mm masonary bits and I can only get so far...
It's as tough as a rock this patio stone!
Simon.
Simon.
That's the trouble with rock ......... hard as stone :D
I find if you're not using an SDS drill then try using progressively bigger bits - start at say a 4mm pilot hole and work up to 10 mm in 2mm stages.
