Whilst trying to get to sleep I (unfortunately) began thinking about running an unRCDed radial for my fridgefreezer and boiler (when I renovate my flat).
I have some 4mm^2 SWA 3core kicking about, but not much. I am thinking about using the SWA for the drop from CU to floor as this will be buried in plaster, then connecting it to standard T+E under the floor (either crimped or soldered). In the kitchen it would be direct clipped on the surface of the wall to a socket marked "freezer only", then on to an FCU for the boiler.
Would this be compliant with the regs? I know it says all sockets "other than a marked dedicated outlet" (or something), so would this be OK, or would the freezer need to be hardwired in to an FCU to avoid the RCD?
Cheers and happy xmas!
