SWA with 13a for temporary power to shed...
24 Oct 2005
Lancashire
Hello all, first time post so go easy.....
I'm looking to put a metal twin sw/socket in my shed, approx 25 mtrs from power source (garage)
I have twin sw/socket already in the garage, is it possible to simply attach a 13a rubber plug to some 1.5mm 3c swa and plug into the garage socket, then run the SWA across the garden (pinned and supported to the fence by cleats),and attach directly into the new metal twin sw/socket to be installed in the shed ?
I have concerns over the new colours of the SWA (Blk,Gry & Brwn) and also the earthing of the braid.
I have BW20s kit, but simply don't know how to use it.
Any help / advice greatly appreciated.
You cant connect a swa into a plug top!,
For power 2.5mm2 3 core SWA is Req.
You would need to have it coming from a metal clad switched spur in your garage.
All outside power is required to be RCD protected.
SWA need knowledge how to terminate, which you would need to be shown how to do!
Sorry but I Can't really help anymore...
Best bet get a sparky in as it's a special location in the building regs 2004.
no it isn't.
The braid NEEDs to be earthed using a proper GLAND and BANJO, fixed into an adaptable wall-mounted box AT BOTH ENDS. Also, running it on a fence is not permitted.
Thanks guys....confirmed my thoughts.
How about standard flex (2.5 3c) ran through a flexible conduit for protection ?
flex is fine, but flexible conduit offers very little extra protection. For temporary measures, as this is basically a plug-in extension lead, cant you use artic flex (bright blue or yellow) and string it up high on a fence (so you dont forget)? Just dont fix the socket in place in the shed, to keep things temporary and keep the part p enthusiasts at bay :wink: Also, need a way of restraining the flex in the socket . . .
Best option would be to use SWA buried and properly terminated though.
