Hi
New here just found the site after getting really frustrated with a leak...
Im nearly 75 so before I get a quote I would like your guys opinions please
The guttering is floplast 114mm square line, then 65mm downpipe square ....black all fitted 2017
Someone had the bright idea to clean the downpipe and after that it leaks only in heavy rain.
We got someone to silicone the joints until we fix it but I have had enough although that did work.
The down pipe has a swan neck at the top with an offsett attached (where it leaks) then a small section of 65mm square pipe... then another offset (leaks a bit here too) then a downpipe with nothing else attached.
Rest of it is 100% just the two offset joints.
Ive been told the downpipe has been lowered by 2 inches and that the bottom should not be touching the grille as things can grow up it.
Shall I just order two new offsets and another section of square pipe to make a new swan and also trim the downpipe at the bottom and add a shoe?
These are the things Ive been told by someone I know but he is out of england so any help ....would be amazing ....
thanks
