Hi All,
I have a standard pendant light near loft hatch which gets a bit in the way so I would like to swap for a spot light so its surface mounted is this easy to do as I will have a live, neutral and earth, that I can just fit to the spot light. It is only a small area to light so does not need to be bright and are the energy saving ones that take a while to light fully worth having in place of a GU10 type, it wont be used too much.
I had an electrician in recently to add an extra light to my loft so would not tackle anything tricky but hope this would just be straight swap other having to cut a larger hole.
