We currently have a Swiftflow 100 Combi boiler. It's quite an old one with a constant pilot light.
1. The issue we have is that the shower and kitchen HW only comes on if the flow of water is on full. The shower for example does come on initially but goes cold after 3 minutes. I have to run the bath HW tap until it heats up again, then reduce the bath tap to a slower flow giving pressure back to the shower.
The shower flow and the reduced bath tap flow are enough to keep the boiler heating the water. If I turn the bath tap off the shower goes cold again after a few minutes.
Within a Swiftflow 100 is there a way to change when the boiler kicks in to start heating the water. It needs to come on with a lower flow of water rather than the full flow we have to do at the moment.
The bath tap and bathroom sink tap are the only ones giving enough flow to maintain constant HW.
We've had an engineer around who has said the boiler is probably dirty and due to it being so old, better to get a new one rather than spend a lot to repair it.
Any advice appreciated on this one!
2. We may need a new boiler. The engineer has said they have access to Baxi and another make (can't remember).
They mentioned they have a good warrantee and are easy to fix.
I'd rather have a boiler that's going to last without repair vs a boiler that goes wrong more often and is easy to fix.
Can anyone recommend a good robust Combi ?
3. I want to check the thermostat on the shower (runs off mains). The top dial is water flow. the bottom temperature.
If I take the plastic cover off the temperature dial there is a screw behind. Can I remove the screw to access the thermostat without needing to access anything first?
I just want to check it's clean and not stuck in anyway.
Many thanks,
Many thanks,
