hi Tony,
Thanks for getting back, and for the sock advice - I would normally use the line, but it's getting to that time of year.
Boiler model is Swiftflow 80 (Honeywell), not yet had any problems with dripping valve. I assumed the stat was internal, don't see any way of controlling heat on the outside. Pressure is at 1.0 bar.
Being a complete amateur (obviously), it may well not be worth fiddling with it. I just thought I'd see if there's anything I can try on the electrical side before calling someone out to tell me I need a new boiler.
>>> and indeed, on another inspection, I've discovered a mouse-nibbled wire right at the back. I will leave you to your Sunday...
thanks,
Ian
