switched live paired with a live (changing ceiling light)
7 Dec 2014
Essex
Hi
I want to change the current pendants for the new fittings I've bought but the set up is a little different to what I've seen online (All the lives together and switch live on its own).
The new fitting only has three terminals (L, N, E)
This is the current set up.
Is this what it needs to be like?
Or do I need to pair the live and switch live in the new fitting like they are at the moment?
Nb. I am planning on using a 15a block for the lives, is this ok?
I think your first drawing has an error as you show both a L & a S/L in the same terminal.
In the second drawing why not put the three E wires in the separate block keeping the fixed terminals for L, N & S/L.
But either that arrangement or your own would be fine I think
Though the first arrangement suggests a second lamp controlled by the same switch
Sorry I forgot to mention that there are two ceiling lights being controlled by the switch.
The fact that there is a live with the s/l is what I'm not sure about.
That will be the S/L going to the second lamp but using the "correct" colour for live,
Wire the new rose exactly the same otherwise the 2nd lamp will be on all the time
Great!
For clarity this is the new fitting.
So I wire all the earths to the E terminal on the new fitting. The S/L and Live that are paired on the old fitting to the L terminal on the new fitting. The neutrals to the N terminal on the new fitting and the two remaining Lives to a connector block.
Would you know if a 15a block be suitable in this scenario?
Sounds OK to me
Yep fine
Because if the light has an earth terminal it's because the light has a body, connected to that terminal, which needs earthing?
Fair comment, looking at the later photo it does.
Little update: lights are up and lookin good! Just wired it the same as how the old pendant was fitted but using a connector block for the two lives and keeping the live and switched live together. :D
The latter two are both switched lives.
They can't be different to each other because they are connected together.
So they can either be both permanent live = both lights on all the time
or
both switched lives = lights able to be switched on and off, and the two lights controlled by the same switch.
