And what boiler, specifically would you specify for the OP given his requirements seem strikingly similar to my own?
Would be a start.Coil rating might be a handy starting point don't you think![]()
Would be a start.
I had RM. make me a 120ltr vented with 30kw/h coil in and a dry pocket.
Not bad recovery time on that one.
Isn't that warranty only if installed by an approved 'platinum' installer?They can be used as system boilers. They have the 10 year warranty. The Intergas system boilers only have 7 years and don't have the remote management facility of the Eco RF range.
More rubber hose in a Veissmann than my Granny's Twin Tub!!! Fit the Intergas.Back to the OP the viessmann setup is my personal preference
The intergas setup is @Dan Robinson personal preference.
Both will achieve the same outcome, installed and setup correctly.
Do you have a heating engineer you currently use?
I'd start there! A lot of the specifics you don't really need to understand.
One advantage of going down the intergas route would be that (and dan would have to confirm this?)
You could install an intergas combi that meets your current needs with some allowances made for upgrades.
If your needs change you could add the unvented cylinder
