Hi
Quick question. I have a system boiler (Worcester Bosch). There is a Magnaclean filter fitted, which I assumed was just on the central heating. Heating was turned on a couple of days ago and the pressure on the boiler has been dropping. Last night I made sure the heating side was turned off, wrapped kitchen roll around all rad valves p/w at each rad end, around p/w below boiler and around magnaclean, re-pressurised to 1 bar and left it until this evening. Pressure has dropped by somewhere between 1/3 and 1/2 bar. Heating definitely hasn't been on. Hot water did come a bit earlier for an hour or so. I did notice the magnaclean was hot (it is located immediately below the boiler).
First question - should the magnaclean get hot when just the hot water is on? I thought the m/c was just attached to the central heating side. Can the HW side mix with the CH side e.g. if the diverter valve is faulty?
Second question - if there are no sign off leaks anywhere on the central heating, what can cause the pressure to drop, especially when the heating hasn't been on? Could it be something to do with the expansion vessel?
I'd appreciate any thoughts.
Many thanks.
RVS6
Many thanks.
RVS6
