system boiler
29 Nov 2009
Antrim
Hi I'm looking for the best way to connect two radiators in my garage,the boiler is in the garage also do I just connect new rads into the side of the boiler that as the two pipes coming out?. Should I have the top pipe coming straight out or point it down.
HiFi01";p="2515441 said:
Hi I'm looking for the best way to connect two radiators in my garage,the boiler is in the garage also do I just connect new rads into the side of the boiler that as the two pipes coming out?. Should I have the top pipe coming straight out or point it down. Sorry its oil central heating system water fill. you have one out let and one return pipe from boiler it looks easy but like to get it right.Before I cut into pipes I have two T compression joints going to the 15m shot off,for new system.
It won't work! :!:
Any extra rads must be connected into the system after the pump and any zone valves, and the return into the correct position to avoid circulation faults.
