Hi All,
Need advice on what to do with our hot water system.
Current set up is a system boiler (Potterton Suprema 60he), copper hot water tank in the bathroom & cold water tank in the loft. Stuart Turner twin 2 bar pump connected to shower in the bathroom.
The shower is great at the moment but the hot water tank only holds 110 ltrs or water so it does not last long so we need a better solution. There is no space to fit a bigger tank in the bathroom so we have decided to fit a new tank in the 3rd bedroom (1st floor) where space is not an issue.
Our dilema is whether to switch over to a mains pressured unvented system or just fit a bigger copper tank in the new location. We plan to go into the loft in the future so getting rid of the tanks up there would be a bonus.
Ourt concern with the megaflo or similar is what sort of pressure from the shower we can expect compared to the current set up which are really happy with.
We renewed the water mains coming into the property to 32mm poly last year & have 22mm copper going upstairs to the water tank & 15mm plastic then copper to the kitchen sink & outside tap. Static pressure varies between 3.25 & 3.75 bar at the outside tap. The flow rate at this tap is about 16lts per minute.
Can we expect the shower to be as good as it is now or will it be worse? Noneone seems able to give us a guranteed answer on this.
