The installation instructions for our Kingfisher Mf Cfl 100kbtu boiler, which is located in the cellar, say there should be a drain point at the lowest point of the system but I can't see one there, though there is one in the hall on the ground floor. Will this present any problems when draining down/flushing the boiler? How does one drain the boiler itself? How does one know if there is an anti-gravity or check valve in the heating flow pipe?
Is power more or less risky vis-a-vis leaks than a mains pressure manual flush, especially on an old system?
Advice/information appreciated.
