Hi all
I am fitting a new tap and want to avoid the use of copper as I have no experience of plumbing/soldering.
I have chosen to use a flexible tap connector. However, I only have a small space between the water feed and the tap tail. A 300mm will not be possible. I wouldn't even be able to loop it.
I do know that 150mm connectors exist, although I need one to fit onto an isolation valve and the tap the other end. Seems like finding a needle in a haystack!
Does anyone know of anywhere that can supply this?
I have attached an image of what im dealing with. The tap tail is longer than shown on the image.
View media item 72715
Any help will be appreciated.
Jonny
Jonny
