HI
I'm planning on fitting a hansgrohe ibox and it has what it describes as G3/4" and G1/2" female threads for connections. It doesn't state whether the female thread is tapered or not but I presume it isn't?
Does that mean I can use something tapered like this to connect my 22mm copper pipe with ? (and similar 15mm/1/2" for the outputs)
http://www.screwfix.com/p/conex-male-straight-connector-taper-302ta-22mm-x/72171 (with loctite 55 or similar)
Or could I use a non-tapered thread which seem to be a bit cheaper?
Thanks in advance if someone could quickly point me in the right direction here.
