Tapping into a soil stack
  • Thread starter Thread starter Deleted member 307320
  • Start date Start date
D
I'm adding a utility room, it's below my ensuite and rather helpfully the soil stack is right outside.
Any tips on tapping into it? Strap on boss, or cut out a section of the stack and slot in a tee with a 40-50mm inlet and two female ends?
The strap on seems easier, but I don't want to take the easy option if it leads to problems later.
Thanks!
Strap boss would probably be easier to install but you have to get the hole and mating surface spot on. You could use a short boss pipe.
