tear in underfelt.
T
thatbloke
just my bloomin luck , moving materials around and accidentally tore a rip in the roofing felt (i dont have a ceiling up yet) , the roof isnt leaking but can i repair this just in case it ever does?
T
thatbloke
i had a good read through that Freddy but lost it when people started slagging each other off. :D
so , taping it isnt an option then? its a counter battened roof. ive just put the bloomin thing on , dont really want to strip it all off again.
3 May 2010
Suffolk
Its worth pulling a few tiles out and patching it up , probably only an hours work then at least you have peace of mind .
T
thatbloke
are cedar shingles easy to take out to patch up the felt?
28 Jun 2005
I don`t think so :confused: aren`t they nailed like slates . What is the material of the " felt " is it some modern breathing fabric or what ;)
1 May 2007
Hampshire
you can take them out just like slates with a ripper. the nails are very fine and will shear off.
T
thatbloke
there are two little nails in each shingle but i really cant see them sheering before the shingle splits.
the felt is a breathable fabric. i have access to the roof from below and was thinking that a slice of fabric fed down into the eaves protection layer at the bottom then held in place with some felt adhesive would do so long as it sagged a bit in the middle although my insulation (cellotex) will be right up against the felt between the rafters.
or , i could use this method.
http://www.youtube.com/watch?v=cMpZqrOPlvE :eek:
1 May 2007
Hampshire
Indeed there are two nails in each shingle, Provided the correct nails have been used they will come out exactly as I said. If you damage a shingle just put another in..
The insulation should not be tight to the underlay....
nice video!
T
thatbloke
nice video!
really? ive counter battened and pulled the felt quite tight. i was under the impression that if i did this i could fill the gap between the rafters with cellotex, its a warm roof on a lean-to. i will be lath and plastering straight onto the rafters (or using plasterboard if i cant make lath and plaster meet regs) which are 150 x 50 , 150 mil cellotex is the recommended minimum for this kind of roof , apparently.
2 Feb 2006
Staffordshire
Breathable membrane should be fitted with a bit of sag betwixt rafters.
You should leave an air gap between the underside of the felt and the top of the insulation.
As stated, what is considered a 'warm roof' is a roof whereby the insulation sits wholly above the rafters.
The way you are doing it will require two fittings of insulation. 100mm betwixt the rafters (thus leaving a 50mm air gap above) and 50mm across the rafters internally prior to fitting the plasterboard.
Don't forget to ensure v.p.l. continuity.
T
thatbloke
ah , see i was told that if its counter battened then the felt could be tighter and draping wouldn't be necessary or i could get away with minimal draping, obviously the counter battens will allow any water flow to get down to the gutter uninterrupted , this way i can insulate right up to the felt.
perhaps i am getting warm and cold roofs mixed up?
i will hopefully be using lath rather than pb.
whats v.p.l. continuity?
