The socket in the photo is a master socket in that it has the bell capacitor, the test resistor and the surge protection device.
However it is NOT the type of master that BT will willingly terminate THEIR incoming cable on. The incomer is terminated on the NETWORK TERMINATION EQUIPMENT which is often called an NTE5
The conductors in the incomer are connected to the BACK of the NTE5 out of reach of DIY fingers because that wiring belongs to BT.
The front plate of the NTE5 can be removed by DIY fingers. It has a plug on it which plugs into a socket in the back half ( the BT owned part ) of the NTE5 to make the connection to the telephone socket on the front and to the IDC ( insulation displacement connectors ) into which the DIY can press in the ends of the internal DIY wiring.
In the event of a fault the front plate of the NTE5 can be removed and a known working phone plugged into the socket of the back of the NTE5 for testing the line. BT test and work up to that socket as that is their property and their responsibility.
No you cannot. The diameter of the incomer may not be the right diameter for the forks of the IDC connector. Two small ( unlikely ) and it will not make a good connection. Too large and it may force the forks apart loosening the connection to the other wire in the fork.
i
You would be better off getting BT to provide a NTE5 as only BT can provide (legally) a BT labelled NTE5
Depending how long the line has been out of use you may find the line has been "parked" at the exchange ( routine testing will have found not NTE5 on the line so will have asssumed it to be open ended and out of service ) so you may have to ask BT to re-connect the line. If a test then finds an NTE5 on the line they may ask questions.
so you can push both the BT wires, and the wires off to the first extension into the same connectors?
i
In your opinion would i be better off acquiring a NTE5 and replacing this altogether?
