Tell me about ~ SDS drills
14 Dec 2009
Essex
I have moved into a flat with solid internal partitions. My hammer drill really isnt cutting the mustard and I have a large larder shelf to remove. So im in the market for an SDS Drill but have never used one before let alone purchased one. I dont want to buy one thats rubbish!
Can you recommend a good 240v sds drill around £100?
Thats very true but I do enjoy having the right tools for the job. My hammer drill isnt exactly a gem (a JCB) so one that could replace that aswell would be good. My folks have offered to buy one as a bday present so it isnt actually costing my anything.
That one looks ok but it doesnt seem to have three functions like most others? I will be relocating switches so will be chasing wires, the chisel function will be handy
In that case buy a bosch blue light sds similar to the one i linked too as in reality an sds drill over 2kg has a very limited range of work as its too heavy for using over head or up a ladder and is only really useful for drilling big holes consistantly or chasing
hmmmm darn this simultaneous posting
in that case if you up your budget 20 quid or so you could get a good one with roto-stop too. Personally i like to use a cheap 40quid job solely for chasing hammer it into the ground and buy another one and save the good one for drilling as using it for chasing etc as well will shorten its life considerably.
Stretch your budget by £22 and get this http://www.bluepowertools.co.uk/products.asp?partno=Bosch-GBH226Dre
Or better still, for a true all-rounder that should be all you ever need, stretch it a little more and get this http://www.longhornonline.co.uk/ProductGrp/bosch-gbh-2-26-dfr-rotary-hammer-drill
Almost the same thing, and both have roto-stop for chiselling, but the second one has a properly-fitting standard chuck as well as the SDS chuck, much better than using an SDS chuck adapter IMHO. It'll probably work out cheaper than buying two drills in the end as well.
i have the gbh2-26dre muggles mentioned and it's a great drill but frankly any bosch blue sds drill will take pretty solid abuse and much more than any most diyers will throw at it. as i mentioned using the roto-stop will wear it out quicker but it should still last a long time with even pretty heavy diy use.
I agree that the dfr with normal chuck is a really good product but for me a non-sds drill is much less useful if its not short enough to fit between joists.
