Our consumer unit has fuses for each circuit, with the main switch for the whole supply being an RCD.
All usually works well, apart from if we have to turn the power off for any reason, and particularly if any work is carried out on the wiring. Then the RCD becomes extremely temperamental and will trip when turning on things like the kettle, vaccum cleaner, lights (but only the LED ones in our kitchen).
It sometimes wont resent unless all the fuses are pulled, it'll then reset OK and not trip when the fuses are put back in, and all is well until we dare turn something back on!
The 'cure' seems to be to put the power back and turn as little as possible on for a few hours, and then all is well.
If we have a power cut, the RCD invariably trips when it comes back on. In these circumstances the RCD will usually reset and we have no problems with it tripping when we turn lights etc on.
The last time we had this problem, I'd turned the power off to replace a double socket with one that contains 2 USB charging ports. Eventually after double checking my connections and resetting it for the umpteenth time it seemed to settle down.
This morning our recently replaced heating pump stopped working. I turned the power off to check the connections in the terminal box that the pump is wired into. I did find one wire that was possibly loose. Turned the power back on, hey presto the pump works again (although it could just as easily have been a stuck relay etc I guess).
Went into the kitchen, turned the lights on, clunk as the RCD tripped.
Reset.
Turned on the wall lights in the kitchen. All fine.
Turned on the LED lights (that had just caused it to trip). All fine
Heating and boiler running, fridge running.
Cooker working fine.
Turned the kettle on. RCD trips.
Reset (had to pull all the fuses to get it to reset).
Cooker etc all working.
Wife turns the LED lights on. RCD trips.
I've reset is (having pulled the fuses again to do so and put them back in one by one). I've left for work with wife cooking her breakfast and told her to not use the LED lights or kettle for a few hours.
Last time we had this problem we were convinced the vacuum cleaner was faulty until we realised that other random things were causing it to trip.
What could cause this problem? If it was a wiring fault then surely it would always trip rather than "sorting itself out" after a few hours?
If the RCD was faulty then again I can't understand why it would start behaving itself after a while.
It might be filters etc on various electronic circuits such as the LED lighting, but then again why would it only manifest itself as a problem when the power is first turned on?
It's baffling. Any advice most welcome before I call an electrician out. We did get them to check it out when they wired our kitchen extension (the problem existed before that work) but they said all was fine.
Is it worth replacing the RCD or could there be more of an in depth problem?
Reset.
