Terminal Block?
22 May 2005
Surrey
Hi.
Quick question.
Iv (permantely) removed a wall light. Which I will fill in the hole in the plaster board. I need to 'terminate' the wires and push them back in to the wall before plastering.
What do you normally do? I'm inclined to use Wago's and insulate with tape.
Any other thoughts ?
You need to either remove cable or make the cable dead!
You cannot bury live cables within walls, if they are not in a permitted safe zone, and be removing the light the safe zone will have been removed also.
