Testing Electric Cooker on standard extension cable
1 Jun 2004
I have an electric cooker (Hotpoint HUE52) that I want to establish has all bits working. I collected it and put it in my garage for cleaning, have tested all by continuity tests, but I supply power normally by standard extension cable, from a normal socket in my maisonette (first floor). I do not have an electric cooker connection in my home, I have gas.
With a circuit breaker at the socket in the garage, and testing only one thing at a time, can I successfully test everything on the cooker?
If the total draw of the cooker is 13A or less, then go ahead with your test.....ensure the cable is uncoiled though!
A cheapo ( Oriental) extension may start to get warm, so don't overdo things.
John :)
just test one ring or oven at a time, for a short time only.
Ah, that suggests my plan is right, thanks.
It is awkward, but I just need to know everything is fine to then formulate the next part of the plan.
You say that your garage is protected by a circuit breaker but you do not say if that is an mcb or an rcd. Faulty cooker elements can sometimes trip an rcd & this will not show up unless you are using a proper insulation tester to check the elements. You will only know the cooker is safe if you do insulation tests as well as continuity tests.
