Testing existing foundations
24 Jul 2023
Anyone know if there's a way of testing the quality of existing foundations. To check if it's strong enough to build a new structure on.
Assuming this is a domestic setting then ordinarily you dig a test pit, dig down until you find the foundation, the hole needs to extend far enough to determine how much wider than the wall it is, then dig down a bit more to find the depth, invite your Building Control officer to peer down the hole and say yay or nay.
I've never known a BCO ask for a concrete test for a domestic job but the strength can be tested, you would send a core sample away to some lab somewhere and they would test it. Might have to have a few cores tested.
I forgot to ask how old the existing property is. Some early footings were very shallow and bricked up from a bed of ballast, so age is important.
I dug down in one area so far. It's at least a metre of concrete.
I'll try and find a company that does it. Might be worth it for peace of mind.
You would normally test the ground soil for bearing capacity not the foundations.
Any foundations would be checked visually for dimension and form, and if need be whacked with a hammer.
Same here I dug down to find the depth of existing, had to dig 2 pits one at the front and one at the back /side. Got my tape measure out and everything for the BCO who just looked down the hole and said yep that's OK
So if it looks right it is right. Plus a bit of a whack. That would save a lot of messing about.
