Hi all
1.I'm a bit confused about what should be tested and when. If i install a security light for example from a fcu i need to complete an electrical installation certificate. correct? do i also need to attach a copy of the schedule of inspections and schedule of test results??? And if I do then what exactly do i test? do i just test the circuit which i've made alterations to and record the results or do i test the whole installation??
2.if i was changing a consumer unit do i then complete a electrical installation cert along with the inspections and test results? and do i test the complete installation as i've changed the protective devices for every circuit?
im currently just doing jobs for friends in the run up to getting my part p and im getting very stressed trying to get my head around everything there is to know.
all help or advice greatly appreciated
cheers Dan
cheers Dan
