    Dismiss Notice
Texecom Connect Room Edit
Discussion in 'Alarms, CCTV & Telephones' started by goodtruth, 17 Feb 2020.
  1. goodtruth
    goodtruth
    30 Oct 2017
    9
    Thanks Received:
    Country:
    Is it possible to edit a room name on the Texecom Connect App or do you have to set the whole thing up again from scratch?
    Thank you.
  2. Sponsored Links
  3. secureiam
    secureiam
    20 Jun 2014
    5,280
    Thanks Received:
    650
    Lancashire
    Country:
    you can setup a new room, switch the device across, and delete the old room
    • Thanks Thanks x 1
  4. goodtruth
    goodtruth
    30 Oct 2017
    9
    Thanks Received:
    Country:
    Thanks as usual Secure I AM!
  5. Bassingbourn Boy
    Bassingbourn Boy
    27 Oct 2020
    6
    Thanks Received:
    Country:
    I have a similar issue with a room that was duplicated during set up - one room was spelt differently to the other! I've switched devices to the correct room but can't see how I delete the duplicated room?
  6. secureiam
    secureiam
    20 Jun 2014
    5,280
    Thanks Received:
    650
    Lancashire
    Country:
    press and hold the room, it should ask if you want to delete it.
  7. Bassingbourn Boy
    Bassingbourn Boy
    27 Oct 2020
    6
    Thanks Received:
    Country:
    Thanks. Tried that and I get a pop-up window 'Choose Action' with the choices Camera, Gallery, Default & Cancel - no Delete .... ?
  8. Sponsored Links
  9. secureiam
    secureiam
    20 Jun 2014
    5,280
    Thanks Received:
    650
    Lancashire
    Country:
    Well that was on android latest version on iOS its probably swipe the room to one side to get edit/ delete options.
    not sure which app your using or which part of the menus you were in.
  10. pcaouolte
    pcaouolte
    15 Nov 2012
    278
    Thanks Received:
    71
    Lincolnshire
    Country:
    In the IOS version of the app you need to go to the menu at the bottom right - General Settings - Sync Panel - Let it do its synchronisation then, when it comes up with a list of zones in orange touch any zone to drop down a list which includes the room that the zone is in - touch the room to bring up a list of all rooms - slide the room that you want to delete to the left to get an option to delete the room.
    It's a good job they have tried to keep the app simple to use!
    • Thanks Thanks x 2
  11. secureiam
    secureiam
    20 Jun 2014
    5,280
    Thanks Received:
    650
    Lancashire
    Country:
    playing with V2 at the minute, overly complicated I think, will get onto the ios system to check.
    have to do a panel sync really, I will look at that after i have got to grips with some V2 bits
    and now my phone wants to do loads of dam updates.....
  12. Bassingbourn Boy
    Bassingbourn Boy
    27 Oct 2020
    6
    Thanks Received:
    Country:
    Thanks pcaouolte that's sorted it - not exactly an intuitive app is it!
    Secure I Am - I'm using v.1 of the Texecom Connect app on an iPad.
  13. secureiam
    secureiam
    20 Jun 2014
    5,280
    Thanks Received:
    650
    Lancashire
    Country:
    V2 is in beta but its very similar to be fair so far
    • Thanks Thanks x 1
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
