Hi
I am just starting the actual install of my premier elite 24 after having spent a few weeks on here and wiring up keypads and PIRs on the kitchen table.
The panel is going into a cupboard in the utility room and I am struggling with placement and cable runs. All the wiring for sensors was done by the electrician when house was rewired and come out of ceiling through hole at top of wall.
What is best practise for getting cables to the panel? Should I be running then in a conduit or trunking? If so is plastic ok?
Otherwise I am trying to see if I can mount it to the back of the cupboard and run the cables behind the board at the back of the cupboard, but that is more tricky than just removing the back board.
Also the rubber feet on the back of the panel. Are they supposed to be removed on install so it's flush to wall or not. I was planning on using that gap to get the cables in to it, but now wondering if I need to cut a hole in the top and run conduit to there?
I hope the rest of the install is more straightforward, now I have worked out eol wiring.
