texecom install app ios keyfob
4 Dec 2012
I have a TEXECOM premier elite 48. I have the com ip installed and it works perfectly on the LAN with Wintex.
But I do not get the app on my iphone to work.
I have the latest version of elite Premier 48 (v2.09) and the last Wintex (V6.02)
This is the screenshot of wintex:
I forwarded the port in the router
This is the screenshot of the ios app
the user code is 2 digits, am i wrong? User 02
What do i do wrong?
I can't get it to work. My wintex works perfect with lan and ip
Pm me and ill have a look for you
If you have personal details being shown remive them and replace them.
You would use the same details for wintex as you would for the app.
the user code ie master is 01, user 2 02 and so on and you have to put the user code in for that user, this is only for the smart key part of the app.
the keypad app should work without this.
what version of of the app do you have.
The port forwarding did not work for certain ports as expected.
The reason being the isp blocked certain ports, when ports that weren't blocked by the isp were forwarded the system worked fine.
