Texecom JAC-0001 connection to panel
17 Feb 2008
Berkshire
Hi, I have totally forgotten and for some reason can't find a video of what i need to do to connect the JAC-0001 to panel. I seem to recall i need to switch something on board (switch) to service? then connect cable and then use the wintex
the usb com, one end plugs in your usb port the other onto the comport to use wintex.
the comport needs to be programmed as not used for the connection to work.
there is no switch, unless you are thing of flashing the panel, in which case that's different thing altogether.
I recall last time moving a switch??
So just open lid, connect to the com port on alarm pcb then connect usb to pc and open wintex?
Actually it is a jumper for commision mode, do i need to move this? Obviously not,used i think for pairing devices.
