Hi, just purchased 2 new texecom odyssey X-be units, but I cannot work out how the cable is inserted through to the pcb to connect it!
Obviously, it enters through the back of the moulding through the triangular opening but I cannot see how it then enters through the clear plastic moulding that protects the pcb.
Does the clear plastic section need to be removed? It doesn't look like it should and even if you did, there doesn't appear to be any route or channelling for the cable.
I could drill a hole near the bottom of the white plastic nr the bottom of the pcb but that's a little dodgy and if so why would they provide the triangular hole in the middle?
I'm sure I'm missing the obvious here but if someone's fitted one, please let me know.
Many thanks
Many thanks
