I’m wiring a Texecom Premier Elite 48 at the moment. I have 10 Texecom Exodus 4W smoke detectors that I am setting up to use the 2-wire Smoke dedicated smoke connection on the panel.
I’ve struggled matching up the instructions supplied with the Smokes with the instructions supplied with the panel. The smoke instructions show:
A&B – Alarm Relay N/C
C – no Connection
D – 0V
E – 12V
F – Latch
The instructions for the 2-wire Smoke on the panel has:
F – 12V from the Panel
E – Linked to the next Smoke detector
D – 0V
My understanding of that is that at the first detector I should have 12V at connector F, which I do. When I go to the second smoke detector I should also have 12V at connector F as it should be looping through to provide power at each detector. I have about 3V.
I’m aware that the wiring method seems vastly different between the two methods above and I’m struggling to see why. The lack of 12V at the second smoke detector suggests I’m doing something wrong, but I’ve no idea what!
Can anyone offer any advice?
Paul.
C – no Connection
D – 0V
E – 12V
F – Latch
D – 0V
Paul.
