Hello,
I'm planning a Texecom premier install at my house and i'm in the process of doing various levels of design work to help in my planning.
In doing so i have come across 3 questions:
1) Im planning to wire up the IR sensors using EOL, but the Panic button and all magnetic contacts will be DP - I have read that it is possible to do this by programming the Premier 24 using the Keypad.
Can anyone see a problem in doing this?
2) I've been looking at the COMIP module and i want to know, what are the functions and benefits of it. i know it can be used to setup the system but is there anything else it does? I.e does it have a built in Webserver i can log into remotely (that would be cool )? does it come with a user manual that shows what all the options are for?
3) out of all the connectors on the Premier 24, which ones need to be 'bridged' if they are not in use?
thanking you all in advance
Sups
Sups
