- Joined
- 27 Dec 2018
- Messages
- 77
- Reaction score
- 4
- Country
Morning All, Firstly I'm an amateur installer but this is the second Premier 48 I've installed as the last one didn't give a single flase alarm or hickup in 11 years
So the new one (Prem 48), we have 8 wired zones to panel, ~12 Ricochet devices, 2 Wired keypads with another 2 zones used on each for impaqs with contacts, 32XPW wireless expander and a smart com wifi/ethernet.
It's pretty much wired up now, just the following I'm either not reading correctly (Going into my brain and out my ears) or haven't solved.
1, Wired 360 Dual tech in garage (large double garge mounted in centre), this seemed the most appropriate sensor for the job from what I read, protecting 1 window, 2 garage doors and a side door). I bought the anti masking version as it was cheaper where I bought it but don't want the anti masking enabled which jumpers do I set to disable it and once disabled i assume I just use normal EOL wiring terminals and ignore the fault output?
2, Bell box, alarm won't be commissioned for about 2 weeks as we're waiting on new front door being installed, can I connect the bell box now and will it hold off for 2 weeks or should I leave it until we're ready for the switch on?
3, I set the alarm up using the keypad last time and it was easy but time consuming, I want to go straight to wintex setup this time, what steps do I need to go through on commissioning to get wintex working via the smartcom straight away? (Can I do the ricochet setups in wintex too?)
4, Ricochet monitor, I assume I just plug onto the COM port in the 32XP-W module?
5, Ricochet zones, I've setup the mounting points for where they are going, I assume I just learn them close to the panel as per manual then go and screw them where their final resting place will be starting with the nearest item first?
6, We're planning on an extension next year so will need to change 2 zones wiring around, what's the correct procedure for doing this with my setup? Would the following be correct, login as engineer, switch off mains, pull the battery backup and commence work or will the bell box go into alarm mode? In the 11 years with my old one I never once had to switch it off.
