    Dismiss Notice
Texecom Ricochet Smoke Alarm
Discussion in 'Alarms, CCTV & Telephones' started by racey1979, 10 Nov 2019.
  1. racey1979
    racey1979
    31 Mar 2015
    72
    Thanks Received:
    7
    Yorkshire
    Country:
    Hi all,
    One of my old Kidde smoke alarms started chirping at 3am the other morning and when I was replacing the battery I noticed the date on the back was 2003....so thought it would probably be a good idea to replace them. Been looking round and not sure what to get. I keep looking at the Fireangel ones but I am a bit put off with the sealed 10 year battery as there are a lot of reviews saying it's more like 2 or 3. I have a Texecom Premier Elite panel with 8XP-W expander and Connect Smartcom so now thinking of going that route and getting the Ricochet smoke alarm. Just wondering if anyone has used one/had any experience with one ? If so are they any good ? Also, if triggered, does it just sound the alarm on the sensor itself or does the alarm panel sound as well ? Or even the external sounders ? o_O If I had two of them can they be linked to one another and would both go into alarm if just one detects smoke ??
    Any help/advice much appreciated
    Andy
  2. Sponsored Links
  3. secureiam
    secureiam
    20 Jun 2014
    5,422
    Thanks Received:
    674
    Lancashire
    Country:
    Check the version of your wireless expander, if its a new panel and expander shouldn't be a problem if the panel has been flashed up then just check the expander version.
    you can have both go off.
    • Thanks Thanks x 1
  4. racey1979
    racey1979
    31 Mar 2015
    72
    Thanks Received:
    7
    Yorkshire
    Country:
    Hi, thank you for your reply it's very much appreciated :) I flashed my main panel back when I installed the Smartcom to version 4.03.00. At the time I ended up buying another 8XP-W expander due to issues I was having. Connection with the Smartplug for example was very buggy. Just looking on Wintex and the 8XP-W is version 3.1.10. Will this be okay ?
    Thanks again
    Andy
  5. secureiam
    secureiam
    20 Jun 2014
    5,422
    Thanks Received:
    674
    Lancashire
    Country:
    2.11 was the panels firmware it was introduced on, which would have been a version 2 expander, so anything n that and above should be fine.
    • Thanks Thanks x 1
  6. racey1979
    racey1979
    31 Mar 2015
    72
    Thanks Received:
    7
    Yorkshire
    Country:
    Sound, will give them a try. Will just get one to start with in case they aren't up to much. Can't find any reviews about them....though I've never had an issue with any of my Texecom stuff so should be good (apart from the buggy Smartcom/app which appears to be good now after firmware updates).
    Cheers for your help (y)
    Andy
  7. secureiam
    secureiam
    20 Jun 2014
    5,422
    Thanks Received:
    674
    Lancashire
    Country:
    I use them, worst thing is battery every year.
    however as a rule I advise on mains smokes first.
  8. racey1979
    racey1979
    31 Mar 2015
    72
    Thanks Received:
    7
    Yorkshire
    Country:
    Yeah I read somewhere only 18 months battery life. To be honest I don't mind changing batteries once a year, I do keep close tabs on my alarm system with wintex and it'll flag up on the main panel I would imagine ? Installing mains powered detectors would be a a lot of work, ripping wood/laminate floors up...sod that :LOL:
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
