Hello
I've installed a Texe Elite 64-w today on v 4.01.03
Most of it went well but I have a few issues I need to resolve and hope the forum can help...
1. Bell box not sounding or strobing
Premier Elite Odyssey X-W was installed.
The device was learnt onto the system fine, put up on the wall, closed up with LEDs alternating slowly (about 3 seconds between LEDs lighting up) and all looked fine on the Ricochet Monitor.
However when the panel goes into alarm mode the bell box doesn't do anything, no sound, no strobing.
Wintex shows the bell box on zone 14 but the zone type is "Not Used" which I'm assuming is the issue but I can't tell what to set it to.
2. Panic Button not working
Premier Elite PA DP-W learned onto the system ok. Rico monitor shows all green, I was also able to see it in a alarm state on the monitor when the button is pressed, then reset back on the monitor after I used the key to reset the button.
Zone type = PA Audible. No attributes.
Any advice please?
Thank you
Any advice please?
Thank you
