Texecom timers
17 Feb 2008
Berkshire
If Timed Exit is set The area will arm after the programmed ‘Exit Time’ has expired. Do timers "Entry 1 Delay time" and Entry 2 delay time" refer respectively to zonez set as "Entry Exit 1" and Entry Exit 2"? So Front door can have shorter entry time than back door for example
What is second entry time for?
entry 1 and entry 2 are the ones you should look at changing only
the second entry time should not be changed!!!!!
When the area ‘Entry Delay 1 or 2’ timer expires, this timer will start and an Internal alarm will occur. If the area is still not disarmed before this timer expires, an Intruder alarm will then occur.
Is Entry 2 delay time the timer that Only effects"Entry Exit 2" so different entry can have different time?
