Evening
I had a side extension built from Sept 2019 until March 2020, unfortunately the builder did not apply for any build-over. The drains for my 2 neighbours met in my garden and then joined the main sewer in the road outside. The neighbour to my left had their pipe diverted into the first manhole on my drive while the connection from my right was joined via a bend under the door for my annex (as per the sketch attached)
The council did not ask for any proof of build-over and I have yet to get it passed because the insulation for the flat roof needs to be changed.
The drainage for my neighbour's pipe dropped (to my left) and it was repaired by Thames Water after they sued my builder, they did various CCTV surveys and the other connection was said to be fine. Do I still need to submit plans or will a letter from the council suffice for the application?
Builder did not provide any cross section for the application so I would need to get notes from the inspector to compile the plan.
Any advice is appreciated
Regards
Regards
